My shee has just gone a bottom end rebui;d, i removed tors prior to rebuild, it ran fine.
started it after rebuild, carby was leakin air, from the cap, so i got 2 new ones, started it again, n the cdi died, got a brand new cdi, it only starts, wont rev off idle, slides are moving, fuel is coming thur, but wont rev.
Can some one help, it sounds like tors is stuck on, but i dont have it????
i i hold it @ w.o.t. it floods n stall eventually.
PLS Help
i put the other stock carbs back on, so its not jetting, e-brake and all tors has been removed, as in all un-pluged, including tors control box, it all run once.
is there any more earthin points on the frame other than the voltage reg and the tabs on the coil????
i did remove the loom when the frame got powder coated, the only 2 points a cleaned for earth was those.
