Rodneya Posted April 12, 2009 Report Posted April 12, 2009 So I did a plug chop after a winter rebuild with HJR aggressive trail port and new top end. Temp was 53 deg and I usually ride around 65 to 70 deg. Do I thing it is a bit lean, but will it be right when the temps warm up? Quote
SAVAGE420 Posted April 12, 2009 Report Posted April 12, 2009 (edited) Looks lean to me bud! Your on stock carbs right? Whats size you have in right now? I would go up a few sizes on your mains till it warms up some bro. I take it you cut into the porcelain on the left one !?! And check it again after going up i would say 2-3 on your mains. Edited April 12, 2009 by savage420 Quote
jbooker82 Posted April 12, 2009 Report Posted April 12, 2009 I would say it is lean too. I dont thing warming up 12 deg is going to make it right on ethier. Maybe if you normally ride in the upper 90's it might be close. josh Quote
Rodneya Posted April 12, 2009 Author Report Posted April 12, 2009 I am running 320's right now with stock carbs. Aggressive trail port by HJR. FMF fatty's. Open air box with K&N. The rings look a bit lighter in the photo, probably from the flash. I will go up a couple sizes and wait for the snow to melt a bit mere before I go out again and see how it looks. Quote
GrMeyer Posted April 13, 2009 Report Posted April 13, 2009 I have a question on the pilots that your running. just got mine dune ported and wanted to see what your running because I getting ready to put my motor back together and wanted to see if i needed to buy some bigger pilots before i start the bike up. Thanks Quote
rubberneck Posted April 13, 2009 Report Posted April 13, 2009 I am running 320's right now with stock carbs. Aggressive trail port by HJR. FMF fatty's. Open air box with K&N. The rings look a bit lighter in the photo, probably from the flash. I will go up a couple sizes and wait for the snow to melt a bit mere before I go out again and see how it looks. If that was a proper plug chop, they look really lean to me. i personaly would go up about 4 main sizes and work your way back down if needed. Id rather be 1 step too fat then too lean. Quote
Rodneya Posted April 13, 2009 Author Report Posted April 13, 2009 I have a question on the pilots that your running. just got mine dune ported and wanted to see what your running because I getting ready to put my motor back together and wanted to see if i needed to buy some bigger pilots before i start the bike up. Thanks 27.5 Pilots Quote
mopar1rules Posted April 13, 2009 Report Posted April 13, 2009 (edited) my mods are very similar to yours, and i'm at 340 mains. i also run 27.5 pilots and stock needles @ stock position. bump your mains to at least 340. your plug chop, i'm assuming was done @ wot? Edited April 13, 2009 by mopar1rules Quote
