4 mill stroker 115 rod
795 66mm pistons
stock head
spacer plate .yea i know junk its temporary.
stock carbs
340 mains
stock pilots
pro circuit platium pipes and silencers
k&n filter with adapter lid off
this thing hauls ASS iv never been on something so extreme and im just starting to finish it all up it the dirt sand i dont have a problem
i went to blast it down a local road and up in about 4th 5th 6th it started slipping and its driving me nuts it doesnt do it in low gears and i wanna see the max power of it
i took my clutch apart again my fibers dont look THAT bad and theres these black o rings in ther and the frictions dont look bad either maybe i need to add 3 HD springs or should i just buy a whole DP clutch kit ??
im going through the same problem with mine. just did a 4mil build myself but have a quite a few more go fast parts and clutch slipped right away. bought an all new clutch kit with hd springs (used all six) and it worked good for about two rides now its starting to slip. id try the hd springs and if that dont work then next is gonna be a lockout. i got one coming so hopefully that will do the trick!
