joee20002 Posted April 6, 2009 Report Posted April 6, 2009 so i am not running a over flow bottle what are you guys doing with the crank case breather tube? Quote
305Shee Posted April 6, 2009 Report Posted April 6, 2009 so i am not running a over flow bottle what are you guys doing with the crank case breather tube? Would like to know also.. Quote
2001Stroker Posted April 6, 2009 Report Posted April 6, 2009 Crankcase breather tube? Or, the radiator overflow tube? My crankcase breather tube in the back just goes straight down. The front one goes up to behind the radiator. Now, the radiator overflow goes straight down, and is zip tied to the frame. Quote
87sheerips Posted April 14, 2009 Report Posted April 14, 2009 Crankcase breather tube? Or, the radiator overflow tube? My crankcase breather tube in the back just goes straight down. The front one goes up to behind the radiator. Now, the radiator overflow goes straight down, and is zip tied to the frame. x2 Quote
rubberneck Posted April 14, 2009 Report Posted April 14, 2009 My crankcase breather tube in the back also goes straight down. Routed it with my vent lines for my carbs so anything that happens to drip ends up on the ground and not the top of the cases. i dont have one in front because i have the direct drive cover. You could just plug the front one if you have a stock cover. Quote
