blaster2006 Posted April 4, 2009 Report Posted April 4, 2009 heya... the lights on my banshee are weird.. they work on and off.. when i switch it on it go's on then after 5 sec it startes going on and off really quickly by itself.. then it go's completely off.. but then when i rev it high it gos back on then on off.. then completely off.. etc etc... this isnt a stator problem knowing it runs perfect... meaning it has nothing wrong with the spark/ stator.. right? Quote
mark101180 Posted April 5, 2009 Report Posted April 5, 2009 (edited) heya... the lights on my banshee are weird.. they work on and off.. when i switch it on it go's on then after 5 sec it startes going on and off really quickly by itself.. then it go's completely off.. but then when i rev it high it gos back on then on off.. then completely off.. etc etc... this isnt a stator problem knowing it runs perfect... meaning it has nothing wrong with the spark/ stator.. right? it could have a bad stator and still run fine b/c the ignition and lighting power are on 2 maybe 3 seperate sets of windings. its most likely not the stator b/c the problem is sporatic, it might be a loose ground wire or the switch like the other guy said. if it were the stator the lights wouldnt work at all or they would be constantly very dim. Edited April 5, 2009 by mark101180 Quote
AKheathen Posted April 5, 2009 Report Posted April 5, 2009 sounds like it could be the voltage reg. or melted wires by the exhaust Quote
2001Stroker Posted April 5, 2009 Report Posted April 5, 2009 Pull the radiator cover off. There is a weather-resistant plug behind there, going to the light switch. Sometimes the wires will get corroded in there. I would also check the ground and the switch. Quote
