kev87 Posted April 3, 2009 Report Posted April 3, 2009 hey ive got an 08 banshee and im trying to fit a tacho to it. except it wont work. just wondering if anyone has fitted one and can help me... thanks heaps Quote
AKheathen Posted April 3, 2009 Report Posted April 3, 2009 hey ive got an 08 banshee and im trying to fit a tacho to it. except it wont work. just wondering if anyone has fitted one and can help me... thanks heaps how are you hooking it up, and is it made for a/c? Quote
kev87 Posted April 3, 2009 Author Report Posted April 3, 2009 no its for dc but even wired up to a battery it still doesnt work. its like theres no pulse at the coil negative terminal.. Quote
vulvafan537240 Posted April 3, 2009 Report Posted April 3, 2009 no its for dc but even wired up to a battery it still doesnt work. its like theres no pulse at the coil negative terminal.. what kind? Quote
kev87 Posted April 3, 2009 Author Report Posted April 3, 2009 http://www.speco.com.au/tachos.html its the white one that goes to 12,000rpm part numba 520-10 its the only one that i could get my hands on. its for both 2 and 4 stroke btw Quote
AKheathen Posted April 3, 2009 Report Posted April 3, 2009 it pulses on the orange wire. you can just wrap a plug wire 10X. don't forget 2ppr Quote
kev87 Posted April 3, 2009 Author Report Posted April 3, 2009 r u sure that will work, wouldnt it need an actual electrical pulse? wat do u mean by 2ppr Quote
vulvafan537240 Posted April 3, 2009 Report Posted April 3, 2009 r u sure that will work, wouldnt it need an actual electrical pulse? wat do u mean by 2ppr does your tach have a ppr setting (pulses per revolutions)? banshees fire twice per stroke, at tdc and btc. Quote
AKheathen Posted April 3, 2009 Report Posted April 3, 2009 it will "sense" the pulse with the wraps. and you set the tack to 2 pulses per revolution Quote
kev87 Posted April 3, 2009 Author Report Posted April 3, 2009 oh, no it doesnt. unless it goes off pulse width. its a fully sealed unit. u can only change it from 2 cyl to 4 cyl. Quote
AKheathen Posted April 3, 2009 Report Posted April 3, 2009 set it to 4 cyl. a 4 stroke 4 cyl only pulses 2ppr Quote
kev87 Posted April 3, 2009 Author Report Posted April 3, 2009 it only has a setting to change between 2 cyl and 4 cyl. wich is join 2 wires for 4 cyl wich works fine on my ute and hav the wires apart for 2 cyl... Quote
vulvafan537240 Posted April 3, 2009 Report Posted April 3, 2009 it only has a setting to change between 2 cyl and 4 cyl. wich is join 2 wires for 4 cyl wich works fine on my ute and hav the wires apart for 2 cyl... like akheathen said, join the wires for 4 cyl. have you tried wrapping the wire around the plug wire? thats how my trail tech vapor is wired. Quote
kev87 Posted April 3, 2009 Author Report Posted April 3, 2009 oh ok. no i'll try first thing in the morning. Quote
c zappy r Posted April 3, 2009 Report Posted April 3, 2009 hey ive got an 08 banshee and im trying to fit a tacho to it. except it wont work. just wondering if anyone has fitted one and can help me... thanks heaps Where did u get an 2008 banshee at? Thought they stopped making them in 2006... Quote
