Two quick questions; first, can the rubber boots be removed from the a-arms to allow them to be powder coated? Also how do you get the bearings out of the swing arm where it connects to the frame? I got the pin out and the seals but those two bearings are bound up tight. I put some wd-40 on them last night and am going to try again tonight, if all else fails I
i'm not sure about the a-arms :shrug:
those swinger bearings can be a real bitch to get out. be glad that your pivot bolt came out. they get rusted in there sometimes too and can be a real pain in the ass. lots of wd 40 or pb blaster, time to soak, and a BMFH. heating it may help if you have the tools to do so.
The rubber boots on the a-arms are held on by a metal ring, get some needle nose pliers and pull her off.
Those pivot bearings don't come out easy at all, plan on buying some new ones cuz those ones wont survive the beating it takes to get em out.
i didn't think the whole ball joint could be removed :huh:
It was my understanding that these were fixed into the a-arm
No they dont come out, I would make sure the are tight because it would be a waste of powdercoat if they are bad.
So i can pull the boots but will need to replace them after the powder coat? Sorry, I'm getting a lil confused!
Yes and they are a bitch to put the clip back on the rubber. I was talking about the ball joint itself, if it is loose dont bother powdercoating the arms. The ball joints are not replaceable.
