tapout94 Posted March 31, 2009 Report Posted March 31, 2009 what would i need to get back to stock from this chain roller? i bought my shee with it on it, and i dont have anything else to compare it to. i dont want it... pics and part names would be helpful if anyone has them. thanks guys! Quote
jbooker82 Posted March 31, 2009 Report Posted March 31, 2009 I would say that big pile of crap bolted on behind the front sprocket is an Amp Link. I would get rid of it. Looks like your going to need the Upper and Lower chain rollers (replace the amp link), and a rear swing arm chain roller. I would also replace the front chain slider that goes over the swing arm. This should be everything you need. It is a little more pricy but all the parts are well made. The rear guid has rollers in it instead of being a one pice hard plastic slider. http://www.tmdesignworks.com/xcart/custome...=305&page=1 Quote
swrbansheeboy Posted March 31, 2009 Report Posted March 31, 2009 yup, thats an amp link. i ran one for a couple years... there kinda like running a boost bottle, the only reason you keep it on is because you like to listen to everyone bitch at you to take it off. except with the boost bottle it doesnt hurt anything where as the amp link can cause drag if the bearings and sprockets get worn out. just pull it off and put a pair of these on there... http://www.rockymountainatv.com/productDet...2#vehicleSelect you've already got the rear chain guide, all you need are the upper and lower rollers. you can actualy get away with running just the upper but it's nice to have them both... Quote
