robert0762 Posted March 30, 2009 Report Posted March 30, 2009 I just found out that the idiot I bought my bike from had the rad over flow hooked into the crankcase lines. my ? is where do these lines belong I have the one from the back and front of the motor T-ing into a long line that goes up to my rad overflow spicket. I just need to know where its supposed to go. i'm going to just cap off the rad cause the overflow is already gone thanx in advance Quote
yamshe Posted March 30, 2009 Report Posted March 30, 2009 mine go out the back of the motor by the swingarm Quote
robert0762 Posted March 30, 2009 Author Report Posted March 30, 2009 mine go out the back of the motor by the swingarm ?????????? Quote
jbooker82 Posted March 30, 2009 Report Posted March 30, 2009 The one that is hooked to your rad just needs to be ran through the square loop that the throttle cable and clutch cable go through. Then just let it dangle down. Then you need a hose that runs from the radiator to the coolant bottle, it needs to be hooked to the bottom of the coolant bottle. josh Quote
robert0762 Posted March 30, 2009 Author Report Posted March 30, 2009 Thanx do you think I need to flush the tranny out. I check the dip stick all the time and i dont see any water mixed in so it should be good huh Quote
jbooker82 Posted March 31, 2009 Report Posted March 31, 2009 You could always flush it out with a couple of quarts of ATF type F. I wouldnt flush it out with 10 dollar a quart gear saver. Quote
