I removed my TORS unit this weekend and found when I was done i had no spark when I checked the plugs. I followed the steps below:
HOW TO DISCONNECT/REMOVE TORS ON BANSHEE:
1. Unplug the wires coming out of the TORS carb caps.
2. Follow those wires back to the wiring harness and cut the plugs off as close as you can and put a piece of small heat shrink tubing over the end of each wire and shrink it. then tape them into the harness.
3. Unplug the TORS brain box. It
