Woody 350 Posted March 30, 2009 Report Posted March 30, 2009 I removed my TORS unit this weekend and found when I was done i had no spark when I checked the plugs. I followed the steps below: HOW TO DISCONNECT/REMOVE TORS ON BANSHEE: 1. Unplug the wires coming out of the TORS carb caps. 2. Follow those wires back to the wiring harness and cut the plugs off as close as you can and put a piece of small heat shrink tubing over the end of each wire and shrink it. then tape them into the harness. 3. Unplug the TORS brain box. It Quote
Building my First Posted March 30, 2009 Report Posted March 30, 2009 Where did you find this guide? Quote
Building my First Posted March 30, 2009 Report Posted March 30, 2009 I don't remember a wire on the clutch perch. The only thing I can think of, maybe one of the wires is still making a connection. Did you cap them or use heat shrink? Here is a good guide. http://www.bansheehq.com/forums/index.php?...hl=tors+removal Quote
Woody 350 Posted March 30, 2009 Author Report Posted March 30, 2009 Where did you find this guide? www.angelfire.com/extreme2/yambanshee/techtips/tors.html Quote
