i am thinking a 13 in the front and a 42 in the rear that sound about right?
I ran a 14/46 on my bike drag racing....
I played with the gearing a bit, and that was the gearing that gave me the best times.
Dan
Without knowing your mods and tires and surface you are running on we cannot really even start to give you an answer.................................... But if I were you I would run 19 36....if you cant pull that you need a bigger engine!!!!!!!!!!!!
lol thats 500ft gearing, I run 18-34 a few times out this way
sorry for not posting what i have done..
421 cub,
40mm lectrons on alky,
shearer out of frame small bore,
tires are 12 paddle 22"
cannot really think of anything else. let me know what you guys think i should be running? i think a 13 42 should be ok?>
18 -34 seems to tall..
421 cub,
13/42 you will run out of gear way before the traps in 500 feet..................
I'd dare to say you'd run out of gear before the traps at 300 feet with that gearing.
sorry left that out also i weight about 280 and its a plus 8 swingarm...
Well with that weight, you'll probably need a little lower gearing than what's been recommended.
