Ok so heres the deal i sent a post awhile back, I fouled my right plug and got a knock, so i decided to rebuild top half, just got everything together and decided to check carb sync and lord and behold right carb is lagging behind. So heres my q what nut do I turn on top of the tors to adjust. Thanks in advance
As far as I know that is the only way to do it. In theory if they are synced at idle they sould be in sync all the way through since the idle screw is just lifting the slide by the cable. Best thing to do is get rid of the tors.
Another question are the slides even at idle if they are your tors may be jacked up. Make sure they are in sync at idle.
Edited by Woolfman
