Ok guys here is my issue. I am putting my shee back together after repainting the frame and going through the engine to port and freshen it up. I am not too fimiliar with how the clutch goes back together and forgot how it came apart. I have it back together without the engine cover on it and I put it in gear and the clutch doesnt lock instead the outer cover just turns and the adjuster nut wont unthread from the screw. Any Help Would Be Appreciated Thanks.
did you remember to put the thrust washer on the trans primary
shaft before you put the clutch basket on?
hmmm....
Edited by Hilarious
i figured it out it was a combo of the adjuster being way out to lunch and the plate on the end wasnt sitting right
