RARRACING Posted March 27, 2009 Report Posted March 27, 2009 what would cause it to idle fine but not rev jets are fine Quote
AKheathen Posted March 27, 2009 Report Posted March 27, 2009 what would cause it to idle fine but not rev jets are fine likely the tors, if your sure the jetting is right Quote
byrdmanracing Posted March 27, 2009 Report Posted March 27, 2009 if it ran good before it wouldnt rev, what did u do different. (engine wise) Quote
RARRACING Posted March 27, 2009 Author Report Posted March 27, 2009 if it ran good before it wouldnt rev, what did u do different. (engine wise) vitos pistons milled head fmf pipes port n polish Quote
RARRACING Posted March 27, 2009 Author Report Posted March 27, 2009 did u do a compression test? im trying to find my tester Quote
byrdmanracing Posted March 27, 2009 Report Posted March 27, 2009 i would check that out. it should be around 100 psi. give or take. if its like 20, 40 or lower. something is wrong. if it has good compression then its something electric. Quote
RARRACING Posted March 27, 2009 Author Report Posted March 27, 2009 did u do a compression test? i cant find it but there new pistons and it ran fine a few days ago and just stopped? Quote
byrdmanracing Posted March 27, 2009 Report Posted March 27, 2009 what does the spark plugs look like? Quote
RARRACING Posted March 27, 2009 Author Report Posted March 27, 2009 what does the spark plugs look like? ya i put new ones in to see if that would change it Quote
AKheathen Posted March 27, 2009 Report Posted March 27, 2009 does it cut out like a lightswitch as soon as you give it a little? does it only rev a little bit? does it sputter out? Quote
byrdmanracing Posted March 27, 2009 Report Posted March 27, 2009 what did the old plugs look like? black and wet or white and ashy? its sounding like it may be electric. Quote
RARRACING Posted March 27, 2009 Author Report Posted March 27, 2009 what did the old plugs look like? black and wet or white and ashy? its sounding like it may be electric. they were a little wet but looked good wen i was testing the timing how it feeds off the spark when i gas it the light shuts off for a split sec then goes back on Quote
byrdmanracing Posted March 27, 2009 Report Posted March 27, 2009 i think u should check the electric. follow the wiring harness make sure every thing is hooked up right. it maybe something to do with the stator. Quote
RARRACING Posted March 27, 2009 Author Report Posted March 27, 2009 i think u should check the electric. follow the wiring harness make sure every thing is hooked up right. it maybe something to do with the stator. ill go check that then post back Quote
