Creetan Posted March 26, 2009 Report Posted March 26, 2009 I am looking at buying a 1999 Banshee with some work done to it. i know nothing about Banshees so figure I would come here and get some educated advice. The Shee has rebuilt motor bored 30 over, has a coolhead with 21cc domes, dirtbike crank,bigger carbs( not sure on size), Vforce 3 reeds, CPI Drag pipes, and a +6 swing arm. He says it dynoed at 72hp. Does this sound about right? He says it has a new transmission also. It has 10 hours on it since build. the guy says its been sitting up for a couple months and when we started it the other day it was smoking alot. I know its a 2 stroke so it's going to smoke some but this was like a fogger. He said he uses 32:1 mix which is richer in oil he said. Also might be because the bike has sat and the oil and gas sperated some?? Whats a Shee like this worth and is the smoking a serious problem? Sounds awesome! Any input is greatly appreciated. Quote
zach45 Posted March 26, 2009 Report Posted March 26, 2009 smoking how much? what color smoke? dirtbike crank? im almost sure there are no 2 cylinder d-bikes... Quote
Creetan Posted March 26, 2009 Author Report Posted March 26, 2009 smoking how much? what color smoke? dirtbike crank? im almost sure there are no 2 cylinder d-bikes... Its white smoke. Reminds me of when a 4 stroke rings are going out. Hell its like having a personal insect fogger. Quote
2Stroke4LIfe Posted March 26, 2009 Report Posted March 26, 2009 (edited) Its white smoke. Reminds me of when a 4 stroke rings are going out. Hell its like having a personal insect fogger. White smoke is Usually coolant leaking into the cylinders...Could just be a bad seal. Edited March 26, 2009 by 2Stroke4LIfe Quote
Creetan Posted March 26, 2009 Author Report Posted March 26, 2009 White smoke is Usually coolant leaking into the cylinders...Could just be a bad seal. If it was leaking coolant into the cyclinders that means it would be losing coolant right? Well after running it for awhile the coolant is still the same. With as much as it smoke it would have to be burning alot of coolant. I am used to popped head gaskets and this doesn't remind me of one. Like I said it reminds me of when a 4 stroke rings go bad. Quote
spurdy Posted March 26, 2009 Report Posted March 26, 2009 White smoke is Usually coolant leaking into the cylinders...Could just be a bad seal. I 2nd the coolant leak. Strange about the dirtbike crank thing also, thought all dirtbikes were singles. SP Quote
Creetan Posted March 26, 2009 Author Report Posted March 26, 2009 I 2nd the coolant leak. Strange about the dirtbike crank thing also, thought all dirtbikes were singles. SP Ok so sounds like I won't be buying that Shee. Quote
xater Posted March 26, 2009 Report Posted March 26, 2009 could be old gas, my sleds smoke like a volcano the first stat up with old gas. Quote
zach45 Posted March 26, 2009 Report Posted March 26, 2009 i think its old gas/oil could be in the pipes/carbs/ETC whats he asking for the bike? Quote
Creetan Posted March 27, 2009 Author Report Posted March 27, 2009 i think its old gas/oil could be in the pipes/carbs/ETC whats he asking for the bike? Well I was going to trade him my Brute Force 750 for the Banshee and a 2005 Honda 450R. The 450r dynoed at 60hp. I don't know alot about sport quads only 4x4's. So I have no clue if this is a good deal or an even deal or if I am getting screwed. Quote
TJScott Posted March 27, 2009 Report Posted March 27, 2009 Well I was going to trade him my Brute Force 750 for the Banshee and a 2005 Honda 450R. The 450r dynoed at 60hp. I don't know alot about sport quads only 4x4's. So I have no clue if this is a good deal or an even deal or if I am getting screwed. you would be getting screwed by trading him either one of those seperately as it is. unless you are saying you get the 450 along with it, then its a good deal. Quote
Creetan Posted March 27, 2009 Author Report Posted March 27, 2009 you would be getting screwed by trading him either one of those seperately as it is. unless you are saying you get the 450 along with it, then its a good deal. Correct he wants to trade me BOTH The Banshee and the 450R for my Brute. Quote
