With all my mods listed... Would i notice or feel a benefit if i moved my plate from 4 to 5 or 6? What would it hep or hurt?
you probably cant tell to much of a difference between 4-5-6 degrees, more timing, the more chances you have of detonation. you might have to switch to 110 octane, if you already run 110 octane then go ahead and bump the timing up more.
i dont know, probably not your not talking about night and day difference. 1-4 is slightly noticeable after that its just by feel try it and find out
I actually remember thinking that +7 was a little bit snappier than the +4, seemed to like it better. now, with the milled head, i'll probably stay at 4, but i will try 7 again.
wat does advancing the timing plate really do? i have mine at +4. is it bad to go any higher on stock cylinders and stock cranks?
