  • Replies 38
  • Created
  • Last Reply
Top Posters In This Topic
well i got it to run in 2nd and in 4th idk????
You sure you put the clutch together right? Pressure plate indexed correctly?
If the pressure plate is rotated wrong, it will not apply pressure to the plates. Seen that toooo many times on DIY clutch builds. Just does not sound like you did anything to kill the trans. Possibly just an assembly issue.
Brandon
Brandon
what do you mean indexing wrong what way should it rotate?
let me ask you this..sorry if it has been asked already,but do all the gears go in when the bike is off??if everything feels good with the bike off you might havee a problem with one of the forks..
