sir_247
Everything posted by sir_247
  1. well after i put the motor back into my shee i turned it on and i had put the needles wrong and was at full blast after that i put the needles in the proper position and my shee ended up with gunked up carb so i pulled them and got the jets and the main mixed up my question is are they the same or is on bigger or smaller thanks for the help
  2. i pulled the motor from my banshee and im going to put it back now but can seem to find where this hose went
  3. yea i did and they do feel fine but 5 and 6th dont go in??
  4. well after talking to the guy who rode my bike he ******* said that he "might" have slamed a gear down at high revs! idk if this helps???
  5. what do you mean indexing wrong what way should it rotate?
  6. well i got it to run in 2nd and in 4th idk????
  7. well i adjusted it and still no go it turns on and when i let the clutch go it doesnt go anywhere buy it doesnt shut off any more you put it in gear and when you let the clutch out it revs but doesnt go anywhere i got the shift shaft thing and adjusted it
  8. well i installed the new clutch kit and pancake and no go it still does the same thing i need help guys dont know why this is happening i didnt adjust the shift shaft, can that be causing this problem?
  9. i get it a little but its not clear, what do i bend and what am i looking for is it the space with that star and the little lever? thanks for the help everyone i ordered my cluth basket inner plate and clutch with the pancake
  10. do you guys know what the size of the clutch boss nut is?
  11. does the pancake replace this?
  12. so basically all i need is a clutch basket and clutch and springs and a pancake do i need a new gasket?
  13. the shift shaft is all the way in where does the pancake go?
  14. ok so i got it in neutral and what is the shift shaft???? is this it? other
  15. i noticed that the clutch basket has like groves going towards inside as if they were slanted is that wear? so the bike should kick in to neutral?
  16. well it came out can you give me a link to where i can buy the clutch and the "pancake" thanks very appreciated guys
  17. are you guys talking about this? what do i need to do know?? sorry but im a noob i also found this
  18. also it doesnt want to go into neutral. The plates bearly open when you pull the clutch in. the oil was really brown.
  19. well i went riding to dumot dunes and let my friend borrow my bike and when we were going up a dune the bike suddenly stopped and shut off after that we hauled it back to camp and turned it on and when i put it in gear it doesnt go anywhere it just rev's. i tryed all the gears and wont move.as soon as you let all the clutch out it turns off Thanks for the help guys, greatly appreciated
