joee20002 Posted March 10, 2009 Report Posted March 10, 2009 brand new in the box craftsmen powder coating gun 120.00 shipped i will get some pics up.... Quote
banshee_terror_ Posted March 11, 2009 Report Posted March 11, 2009 were and what type of paint do you use Quote
joee20002 Posted March 12, 2009 Author Report Posted March 12, 2009 were and what type of paint do you use you can get some powder at sears but you can get anything you want on line.... Quote
banshee_terror_ Posted March 12, 2009 Report Posted March 12, 2009 do you know pacifically what it is called. the powder i mean Quote
joee20002 Posted March 12, 2009 Author Report Posted March 12, 2009 do you know pacifically what it is called. the powder i mean its called powder coating i dont know... lol look at this link... http://www.caswellplating.com/powder/index.html Quote
banshee_terror_ Posted March 12, 2009 Report Posted March 12, 2009 allright so what do you do with the paint or is the powder the paint as well Quote
04srt4black Posted March 12, 2009 Report Posted March 12, 2009 (edited) Powder coating means you heat the part (has to be metal or aluminum and able to withstand heat) to 350* or sometimes higher , then you ground the part (grounds attached to the powder coating gun) and coat the part with the powder , stick it back in the oven let it cook 10-15 minutes and let it cool and your done . Fairly simple to do BUT you cant use your household oven , well unless you ever want to cook anything in it again ,lol . Edited March 12, 2009 by 04srt4black Quote
joee20002 Posted March 12, 2009 Author Report Posted March 12, 2009 Powder coating means you heat the part (has to be metal or aluminum and able to withstand heat) to 350* or sometimes higher , then you ground the part (grounds attached to the powder coating gun) and coat the part with the powder , stick it back in the oven let it cook 10-15 minutes and let it cool and your done . Fairly simple to do BUT you cant use your household oven , well unless you ever want to cook anything in it again ,lol . well said thank you.... Quote
joee20002 Posted March 14, 2009 Author Report Posted March 14, 2009 new price 100.00 shipped..... Quote
joee20002 Posted March 16, 2009 Author Report Posted March 16, 2009 ttt........................... Quote
jclc43837 Posted March 16, 2009 Report Posted March 16, 2009 Powder coating means you heat the part (has to be metal or aluminum and able to withstand heat) to 350* or sometimes higher , then you ground the part (grounds attached to the powder coating gun) and coat the part with the powder , stick it back in the oven let it cook 10-15 minutes and let it cool and your done . Fairly simple to do BUT you cant use your household oven , well unless you ever want to cook anything in it again ,lol . ive been powdercoating for years you dont heat the part up first you just ground it powdercoat it and then put it in the oven you are talking about hot flocking and by the way you heat it to 150 if you are going to hot flock also it does not give it an even coat. that is done when you have a cheap gun and your trying to do a double coat or tripple and like i said it is not even. Quote
BasicBajaX Posted March 20, 2009 Report Posted March 20, 2009 ttt.............. Is this the gun you do not need compressed air? Quote
