donkeypuncher Posted March 5, 2009 Report Posted March 5, 2009 so i'm in the process of installing a set of 33PWK's and boss intake on my bike, but i noticed that one carb sits lower than the other. :ermm: i tried switching them around but no matter which side its on one of the carbs still sits lower than the other. i'm wondering if this is normal? have you guys noticed this with your carbs? if so, which side should sit lower, or does it matter? thanks, Alec. Quote
locogato11283 Posted March 5, 2009 Report Posted March 5, 2009 its prolly the intake, not the carbs.. Quote
donkeypuncher Posted March 5, 2009 Author Report Posted March 5, 2009 its prolly the intake, not the carbs.. that was my first thought, but when i switched the carbs around (left carb to right side and right carb to left side) the same carb that WAS lower on the left was still lower when i put it on the right side. but if it doesnt matter which carbs goes on which side anyways (since they both have chokes) then i guess its not really a big deal. :shrug: Quote
dragbanshee98 Posted March 5, 2009 Report Posted March 5, 2009 its prolly the intake, not the carbs.. its not the intake because he said that the same carb sits lower no matter which side it sits on... i would check to make sure that u got both bowls the same size? other than that idk what the problem would be Quote
roboz Posted March 6, 2009 Report Posted March 6, 2009 I just put 33's on mine and they both sit at the same height. I went and double checked and no difference. Quote
