I just took the clutch fibers and steels out to be replaced with a new clutch. Noticed the pressure plate has some wear..."funny wear". Guys, I've got a machine shop next to my work, I've been considering having it turned a very very very little bit to have the wear pattern broken. I'd hate to trash it. It's a Hinson and it wasn't exactly cheap. Let me know if its worth a try.
ive seen plenty of pressure plates wear. if you run your finger from the inside to the outside, you can feel it hump up a little. start at the spot where the bolts go through and run it toward the edge. in some cases you can feel the difference pretty easily.
