BANSH-alena-jol-EE Posted February 17, 2009 Report Posted February 17, 2009 i got a stock air box, want to try it with out the lid, will it give more power? do i have to re jet? Quote
blaster2006 Posted February 17, 2009 Report Posted February 17, 2009 i got a stock air box, want to try it with out the lid, will it give more power? do i have to re jet? yes you obviously have to rejet if you let more in, by removing the lid. if you only remove the lid and keep the airbox and stock filter, just bump up 3 sizes or 4 sizes up on the main jet, but im pretty sure the stock filter is not made to run without the lid. just get K&N filter for the airbox, or even getter get the pods. Quote
Rodneya Posted February 17, 2009 Report Posted February 17, 2009 1 size bigger on the mains, maybe. Depends if you are slightly rich with the lid on or not. My jetting is slightly rich with the lid on, and I can run with or without a lid without changing anything. The lid does act as a volume control though. Quote
BANSH-alena-jol-EE Posted February 17, 2009 Author Report Posted February 17, 2009 i have a k and n filter, i have never jetted before, is it the very bottom of the plug that u check to see if its rich or lean, mine had a dark oily fluid on the bottom of the spark plugs....this is with lid on, i have sst pipes and shes already jetted, i have vf3 reeds on the way with boost bottle and amr stage 3 cdi, how will these add ons affect the jetting? Quote
lokisbuddy Posted February 18, 2009 Report Posted February 18, 2009 I think you should do a plug chop and see what it looks like. Oh and no need to rejet for the boost bottle if you run R134B boost addative in it, any other addatives and you may have to bump up a jet size. :biggrin: :biggrin: Quote
BANSH-alena-jol-EE Posted February 18, 2009 Author Report Posted February 18, 2009 yes you obviously have to rejet if you let more in, by removing the lid. if you only remove the lid and keep the airbox and stock filter, just bump up 3 sizes or 4 sizes up on the main jet, but im pretty sure the stock filter is not made to run without the lid. just get K&N filter for the airbox, or even getter get the pods. what are "pods?, and man when i pulled my plugs they were a dark color, thats with the lid, so does this mean shes running rich? Quote
indiana banshee Posted February 18, 2009 Report Posted February 18, 2009 You may also need to do some port work for that boost bottle. Quote
DallasGDub Posted February 18, 2009 Report Posted February 18, 2009 what are "pods?, and man when i pulled my plugs they were a dark color, thats with the lid, so does this mean shes running rich? Pods are filters that you place one on each carb and you remove the entire airbox. Pulling the plugs wont help you determine of your rich or lean. If you can not tell by the way it runs, you have to follow steps to find out. Many opinions, here is what I do. Warm the bike up on the old plugs, then turn it off. Put in a brand new set of plugs, and put the old set of plugs in your pocket. From start, run thru all the gears at WOT(wide open throttle), pull the clutch, hit the kill switch while in 6th roll to a stop. Then pull the plugs. Place the old plugs back in the bike to get you back to where you came from. Use a flashlight to look down inside the new plug you used for WOT. You should see a nice brown choco ring around the base of the electrode. If its really dark/black your rich. If it is light brown cigarette stain color, your lean. If you can not see it, proceed to chop the top of the threads of the plug down until you can. Check out the Jetting section. MANY threads cover all this. Even detailed stickys at the top. Quote
killshee Posted February 18, 2009 Report Posted February 18, 2009 will u send me ur stock crossover? Quote
killshee Posted February 18, 2009 Report Posted February 18, 2009 yes you obviously have to rejet if you let more in, by removing the lid. if you only remove the lid and keep the airbox and stock filter, just bump up 3 sizes or 4 sizes up on the main jet, but im pretty sure the stock filter is not made to run without the lid. just get K&N filter for the airbox, or even getter get the pods. are u stupid read and learn b4 u start throwing out advice b4 u f*ck up someones shee.... dont speek unless u kno what ur talking about. it all depends on the plug chop and if i would have to gess it would b like 1-2 sizes bigger.....arent u the same person that like half of the hq told u ur bike was lean and u argued with them????? :: Quote
BANSH-alena-jol-EE Posted February 18, 2009 Author Report Posted February 18, 2009 Whats your elevation? im at sea level! Quote
vulvafan537240 Posted February 18, 2009 Report Posted February 18, 2009 like everybody else said, do a plug test and see what they look like. dallasgdub explained it pretty well. prolly not ganna need 3 or 4 jet sizes up like blaster06 said hahaha! Quote
brugal Posted February 18, 2009 Report Posted February 18, 2009 im at sea level! 1-2 sizes larger on the mains,adjust the airscrew. Quote
