AKheathen Posted February 16, 2009 Report Posted February 16, 2009 ok, still can't find pics, but i was talking about the little1/4"-3/8" recess cut into the side of the slides @ 45 degree angle Quote
swrbansheeboy Posted February 16, 2009 Report Posted February 16, 2009 (edited) this what your hunting for? (btw, this would be from the left side carb) Edited February 16, 2009 by swrbansheeboy Quote
skinindustries Posted February 16, 2009 Author Report Posted February 16, 2009 ok i had them in right then i figured i did. If i swap the plug wires the bike wont fire will it? just like in a car, but i will try it today i think my plug might be bad cuz when i first started ithad spark and fire on both sides,then all of a sudden nothin on the left. Quote
AKheathen Posted February 16, 2009 Report Posted February 16, 2009 (edited) ok i had them in right then i figured i did. If i swap the plug wires the bike wont fire will it? just like in a car, but i will try it today i think my plug might be bad cuz when i first started ithad spark and fire on both sides,then all of a sudden nothin on the left. it fires a waste spark, like some cars, meaning they both fire at the same time, so you can't get them backwards. thanks, that was what i was talking about Edited February 16, 2009 by AKheathen Quote
skinindustries Posted February 17, 2009 Author Report Posted February 17, 2009 if they fire at the same time why is there 2 pick ups on the flywheel? Quote
swrbansheeboy Posted February 19, 2009 Report Posted February 19, 2009 theres actualy only one pickup rides next to the flywheel, there are two nodes on the flywheel. the coil fires both plugs every 180 degrees on the shee, the nodes are set 180 degrees apart to send the signal to the cdi telling the coil to fire both plugs. since one piston is at tdc and the other at bdc it doesnt matter if both plugs fire at the same time. unlike a car/truck the banshee doesnt have a distributor to direct the spark to a certain cylinder so instead it just fires both plugs at the same time to overcome the lack of a distributor. it's actually a pretty cool idea and comes in pretty handy when troubleshooting problems, i wish i could just swap wires on my mustang to determine if one of my cylinders wasnt working properly.... Quote
