I ran the same set up as spike but I run holeshots
Fastbanshee has the setup. I have run those studs, and they are way better than pretty much anything else. There is lots of biting surface area, and they will not pull out or over flex the tire. The sled studs are nice, but if your on a lake, they over flex the tire and will pull out from time to time. The screw in studs will dull very quickly on pavement though, so you gotta watch that. Replace them before they lost the hex head, or you will play hell getting them out. In the winter I could smoke people with banshees and 250'rs with a POS big red three wheeler just cause I had awsome traction in the icy conditions. A banshee with studs is just killer in the winter. Good times.
