twizted269 Posted February 2, 2009 Report Posted February 2, 2009 are these the same cases? is there anything diffent in the cases themselves for an rz350? i can get a set for $65 with no breaks. thought it would be good deal for backups if they are the same. Quote
lt1bird Posted February 2, 2009 Report Posted February 2, 2009 Im pretty sure they are the same except the rz350's have a provision for the oil injection...I think you simply dont put that gear on....no issue... Quote
2001Stroker Posted February 2, 2009 Report Posted February 2, 2009 i can get a set for $65 with no breaks. What? Even if they ain't the same, that's a steal. I would buy them, just to resell. They usually go for somewhere around $160-$200. Quote
twizted269 Posted February 2, 2009 Author Report Posted February 2, 2009 the upper and lower case are IDENTICLE... side covers are different.. and some of the internals are different just the gears and stuff are different? if the cases are identicle to the shees then ill have an extra set for a spare or build off of. Quote
regalrocket Posted February 2, 2009 Report Posted February 2, 2009 I would love it if these quads were oil injected, Quote
uwenr Posted February 2, 2009 Report Posted February 2, 2009 are these the same cases? is there anything diffent in the cases themselves for an rz350? i can get a set for $65 with no breaks. thought it would be good deal for backups if they are the same. The top case has a hole towards the rear for a speedo cable. I believe there is a thread on here for pluging it. $65 is a steal Quote
