88BANSHEERIDER Posted January 29, 2009 Report Posted January 29, 2009 hey guy i just got my shee started last night and come to find out it is running on half the power it should on the right cylinder i have a 2 into one carb kit it has spark and compression i was wondering if i have the wrong head gasket, i have and aluminum one on there now and cant seem to find one anywhere else does it need to torque down to a diff torque setting or what, I am very confused i am going to do a compression check on it today could sure use the help thanks matt Quote
#1banshee Posted January 29, 2009 Report Posted January 29, 2009 hey guy i just got my shee started last night and come to find out it is running on half the power it should on the right cylinder i have a 2 into one carb kit it has spark and compression i was wondering if i have the wrong head gasket, i have and aluminum one on there now and cant seem to find one anywhere else does it need to torque down to a diff torque setting or what, I am very confused i am going to do a compression check on it today could sure use the help thanks matt when you rev it up does it then have fire on that 1 bank and run good and at idle it stops running on that 1 side and pops? We had an issue like this and it turned to be the fly wheel... my buddy was stumped changeing things left and right and it turned to be the fly wheel... Quote
gsxr to banshee Posted January 29, 2009 Report Posted January 29, 2009 I have the same problem right now on my 03 banshee Quote
killshee Posted January 29, 2009 Report Posted January 29, 2009 I have the same problem right now on my 03 banshee do u have dual carbs or a single ..... if u have duals i just figured mine out have the same problem i ended up havin to take apart my right side carb three times and clean the pilot jet finaly i got all the shit worked out and it runs fine now Quote
killshee Posted January 29, 2009 Report Posted January 29, 2009 hey guy i just got my shee started last night and come to find out it is running on half the power it should on the right cylinder i have a 2 into one carb kit it has spark and compression i was wondering if i have the wrong head gasket, i have and aluminum one on there now and cant seem to find one anywhere else does it need to torque down to a diff torque setting or what, I am very confused i am going to do a compression check on it today could sure use the help thanks matt if u have 2 into 1 carb settup i think that would amost narrow it down to a spark problem IMO but im sure there are other things try switching your plug wires left wire to right plug and right wire to left plug and see if the left cylinder fires up insted of the right Quote
chadj1980 Posted January 29, 2009 Report Posted January 29, 2009 swap plug wires and see if the other side fires.. If it doesnt I would check plug for gas...might have bad reeds in one cyl. Quote
88BANSHEERIDER Posted January 29, 2009 Author Report Posted January 29, 2009 so i think i narrowed it down to the flywheel but i cant tell if it has a break in it somewhere i put a screwdriver in it and it seems to have the same amount of spacing all the way around and doesnt break in the middle of any magnetic pads that are in there i dont know im lost im so close but so far i just want to ride this thing matt Quote
AKheathen Posted January 30, 2009 Report Posted January 30, 2009 so i think i narrowed it down to the flywheel but i cant tell if it has a break in it somewhere i put a screwdriver in it and it seems to have the same amount of spacing all the way around and doesnt break in the middle of any magnetic pads that are in there i dont know im lost im so close but so far i just want to ride this thing matt check the pickup gap on both nodes, sounds like you're sayin you took it off right? give it a shake and see if anything rattles. should be solid. Quote
88BANSHEERIDER Posted January 30, 2009 Author Report Posted January 30, 2009 (edited) doesnt rattle im kinda thinking its the reeds but what if they dont have a crack in them anything else to look at oh yea forgot to add plug is getting wet Edited January 30, 2009 by 88BANSHEERIDER Quote
killshee Posted January 30, 2009 Report Posted January 30, 2009 did u switch the plug wires ... what was the outcome also look for gaps burn and cracks in your reeds Quote
88BANSHEERIDER Posted January 30, 2009 Author Report Posted January 30, 2009 well the reeds are ok i cant figure this damn thing out help Quote
88BANSHEERIDER Posted January 30, 2009 Author Report Posted January 30, 2009 i put a timing light up to it i put an x on one side and a o on the other side it does fine at idle and when i rev it up the o goes away and the x comes there and stays there has anyone ever had a problem with the pickup on the flywheel side or what i want to ride this fucking thing so bad matt Quote
88BANSHEERIDER Posted January 31, 2009 Author Report Posted January 31, 2009 well i figured it out left side was plugged up with a mouse nest thought i got everything out of there of i so happy i can ride it now, its like 10 degrees out and i took for its maden voyage boy was it fun thanks for all the help guys u are the best matt Quote
vulvafan537240 Posted January 31, 2009 Report Posted January 31, 2009 well i figured it out left side was plugged up with a mouse nest thought i got everything out of there of i so happy i can ride it now, its like 10 degrees out and i took for its maden voyage boy was it fun thanks for all the help guys u are the best matt :yelrotflmao: thats something you dont see everyday! Quote
