Millsy240 Posted January 28, 2009 Report Posted January 28, 2009 I just purchased some cylinders and they are reading 65.55 or 2.581". The pistons that came with them are measuring 65.38 or 2.574" the pistons (wiseco) seem to be worn, are these useable? I realize that I need a .003" clearance. If not should I order 65.50 pistons or are they going to measure under 65.50? The cylinders are honed and are measuring 65.55 all the way through. Any help would be appreciated. Thanks in advance. Quote
gregrob Posted January 29, 2009 Report Posted January 29, 2009 I would install the pistons in the cylinder and measure the piston to bore clearance. Like you said it should be .003 I bet it's way off though... if thats what your pistons actually measure Quote
Millsy240 Posted January 29, 2009 Author Report Posted January 29, 2009 I would install the pistons in the cylinder and measure the piston to bore clearance. Like you said it should be .003 I bet it's way off though... if thats what your pistons actually measure Thanks for the reply, I will definately try putting the pistons in the cylinders and try to measure. Are there any special feeler guages for doing this. Thanks again. Quote
Guest utleybanshee Posted January 29, 2009 Report Posted January 29, 2009 I would install the pistons in the cylinder and measure the piston to bore clearance. Like you said it should be .003 I bet it's way off though... if thats what your pistons actually measure how do you go about measuring that..? Quote
NN2 Posted January 30, 2009 Report Posted January 30, 2009 (edited) Nothing special. Just a small basic feeler guage. Similar in concept to a spark plug gapper measuring tool thing-a-ma-bob Edited January 30, 2009 by NN2 Quote
blowit Posted January 30, 2009 Report Posted January 30, 2009 (edited) I just purchased some cylinders and they are reading 65.55 or 2.581". The pistons that came with them are measuring 65.38 or 2.574" the pistons (wiseco) seem to be worn, are these useable? I realize that I need a .003" clearance. If not should I order 65.50 pistons or are they going to measure under 65.50? The cylinders are honed and are measuring 65.55 all the way through. Any help would be appreciated. Thanks in advance. The big question is how did you arrive at your measurements? If you used a caliper, ignore your results. Bore gage and mic is the minimum acceptable method. Your clearance shows .007" with your measurements. I would inspect the bore carefully for damage, taper, and eccentricity. If all that checks out, you may be able to get 65.50mm pistons and pull it back into tolerance. Banshee motors do not stay at .003 clearance very long anyway when "swellcos" are installed. by the way, using a feeler to check clearance is NOT a very accurate way of doing things. If you do not have the tools, have someone do it so you know where you are at. Brandon Edited January 30, 2009 by blowit Quote
Millsy240 Posted January 30, 2009 Author Report Posted January 30, 2009 The big question is how did you arrive at your measurements? If you used a caliper, ignore your results. Bore gage and mic is the minimum acceptable method. Your clearance shows .007" with your measurements. I would inspect the bore carefully for damage, taper, and eccentricity. If all that checks out, you may be able to get 65.50mm pistons and pull it back into tolerance. Banshee motors do not stay at .003 clearance very long anyway when "swellcos" are installed. by the way, using a feeler to check clearance is NOT a very accurate way of doing things. If you do not have the tools, have someone do it so you know where you are at. Brandon I had my neighbor (machinist) measure the bore, with his mic and some telescoping guages. The bore measures 2.581" all the way through, I made sure he checked it at the 6 different spots. No scratched, freshly honed. So what you are saying is don't bother with the pistons I received with the cylinders? Thanks for your advice. Quote
blowit Posted January 30, 2009 Report Posted January 30, 2009 I had my neighbor (machinist) measure the bore, with his mic and some telescoping guages. The bore measures 2.581" all the way through, I made sure he checked it at the 6 different spots. No scratched, freshly honed. So what you are saying is don't bother with the pistons I received with the cylinders? Thanks for your advice. What do the pistons look like? Once the ribs are worn off the piston, they tend to degrade faster due to loss of oil retention. I would inspect them closely but probably would just replace them. .007 is on the high side but I have seen worse. I have seen .015 running. Your call. Brandon Quote
