Millsy240
About Millsy240
  • Birthday 03/15/1978
    Ontario, Canada
    2001 Banshee, Boyesen Rad Valves, FMF Fatty pipes, K&N filter
Millsy240's Achievements
  1. How have you liked the carbs. I have been looking at them but I am not sure if I should go with the oko or these? Any suggestions would be appreciated. Thanks
  2. I had my neighbor (machinist) measure the bore, with his mic and some telescoping guages. The bore measures 2.581" all the way through, I made sure he checked it at the 6 different spots. No scratched, freshly honed. So what you are saying is don't bother with the pistons I received with the cylinders? Thanks for your advice.
  3. Thanks for the reply, I will definately try putting the pistons in the cylinders and try to measure. Are there any special feeler guages for doing this. Thanks again.
  4. I just purchased some cylinders and they are reading 65.55 or 2.581". The pistons that came with them are measuring 65.38 or 2.574" the pistons (wiseco) seem to be worn, are these useable? I realize that I need a .003" clearance. If not should I order 65.50 pistons or are they going to measure under 65.50? The cylinders are honed and are measuring 65.55 all the way through. Any help would be appreciated. Thanks in advance.
  5. Have the spindles been reamed by chance.
  6. I just purchased some 2+1 Burgard a arms and am looking for some aftermarket shocks. I mostly trail ride and a bit of MX. Looking for something like works dual rate. Let me know what you got. Thanks
