I have the screws sitting in my parts box, havn't used them yet. I routed my cable so that just adjusting the cable works just fine, and the idle doesn't change as you turn the handle bars. I had a set of carbs that had the screws in, and they didn;t shave the bosses, causing the bosses to strip from over tightning the screws trying to get idle up. When I replace the carbs, I decided to try it without the screws, seems to work fine. My triple cylinder sled doesn't use screws, uses cable tension, figured if it worked there, it will work here too.
