crashogden Posted January 22, 2009 Report Posted January 22, 2009 right now i have 20cc domes was wondering what yall think is best. thinking about either 19cc or 18cc. Quote
gregrob Posted January 22, 2009 Report Posted January 22, 2009 stock stroke? 4mil? Ported? trail, dune, drag? What fuel do you run? What elevation? How much compression do you want? Need more info. Quote
12mm Posted January 22, 2009 Report Posted January 22, 2009 i have a question also. what power gains going from a 20cc dome to a 18cc ? Quote
crashogden Posted January 22, 2009 Author Report Posted January 22, 2009 stock stroke and bore dune port by hjr any it doesnt matter. live in fort worth, texas... so pretty low dont care Quote
12mm Posted January 22, 2009 Report Posted January 22, 2009 i have a question also. what power gains going from a 20cc dome to a 18cc ? can anyone answer this ? Quote
gregrob Posted January 23, 2009 Report Posted January 23, 2009 You didn't answer the part about the fuel you're running and it does kinda matter. I can imagine your running pump gas at the moment. If you want to stick with pump has, leave your domes where they are. If you want to step up to race has or methanol you could go with 18s or 19s depending on the desired end static compression. I prefer to keep compression around 145psi for pump gas. 160ish for race gas, and 185 max for methanol. You hit a point of diminishing returns where too much compression can actually make it harder for the engine to rev out and hurt your performance. Kinda depends on what you're using the bike for too. Every builder may have a different opinion on that but these are just my thoughts. Kevin and I talked a little about it on the phone today and he seems to agree, on the compression part. Greg Quote
crashogden Posted January 24, 2009 Author Report Posted January 24, 2009 well i run vp 112 50/50 mixed with 93 octane using mixing it bel-ray fully synthetic oil at 36:1. :biggrin: Quote
