yea, but i wouldnt, the banshee is already so narrow, +2's put it on par with new stock quads, i ride in tight trails alot of times and +2 is fine, the handling is way better, u will kick yourself in the ass if you buy stock length ones
Tight trails. Recently we have been riding acrossed some bridges that connect trails. instead of riding comfortable inside the rails on the bridge like the people I ride with, I ride on top. Its a very tight fit. Im in the market for some new a-arms due the condition of the threads on my current ones. Thought I should fork out a couple hundred extra and try to go aftermarket. I could sell my front rims and then get wider a arms...
your better off running +2 a-arms with a shallower offset rim, than standard arms and deep offset, u want the center of the wheel as close to over the top of the balljoints as possible, and i doubt the price will be much different
ive read on here many times about that, having the wheels too far away from the balljoints creates more bumpsteer than the banshee already has
and then the obvious, your brake calipers will be hanging out, also much more leverage on the balljoints and i guess u could say the studs too
ya you may want to think about loosing the offset and getting wider a arms but thats just my opinion. the other q is how wide are the tracks you ride on?
Ah ok ty
