dragbanshee98 Posted January 3, 2009 Report Posted January 3, 2009 i bought a durable HD axle a while back and have yet to put it on the shee. the axle does not have any place to mount the brake setup on it, and was wonderin if anyone could help me in figurin out how to get the setup on the axle. thanks Quote
locogato11283 Posted January 3, 2009 Report Posted January 3, 2009 i believe there is a c-ring and a spot for it on the axle. the brake hub slides on from the sprocket side and sits against that c-ring. Quote
bansheefreak Posted January 3, 2009 Report Posted January 3, 2009 pretty much what loco said... put the brake hub on the axle then slide it thru the axle carrier then add your sprocket hub and the nut,c clip .. when you tighten the nut it will tighten all together.. Quote
dragbanshee98 Posted January 3, 2009 Author Report Posted January 3, 2009 do i just use the brake hub off the stock axle? Quote
bansheefreak Posted January 3, 2009 Report Posted January 3, 2009 if the axle is for a banshee yes... and the stock sprocket hub.. hopefully you got the nut and c clip when your bought the axle... Quote
