sleeper06 Posted January 3, 2009 Report Posted January 3, 2009 Going out of frames, U can see my set up on sig any recommendations,need them silenced for street use will they get fucked up off road on sand dunes exc any body have bad experiances Quote
sheefreak Posted January 3, 2009 Report Posted January 3, 2009 Got a set of Shearers in the For Sale section. Quote
Wildcardracing Posted January 3, 2009 Report Posted January 3, 2009 If the quad is not for strickly drag I would recommend staying with your inframes, the mounts tend to break on the oofs if the terrain is rough. Other than that, I'd hit jeff up and see which set will work better for the porting he did for you. Quote
tony cub Posted January 3, 2009 Report Posted January 3, 2009 its all about the porting you have now.. Quote
kubitza123 Posted January 3, 2009 Report Posted January 3, 2009 Jeff is going to say go with Shearers i bet . I have them on my quad i just got from him a month ago OOF'S both out the left and i like them. But if you plan on duning,jumping at all or have really rough roads i'd keep inframes beause the OOF'S dont mount very sturdy and i think you would crack them out everywhere Quote
RIPPEN Posted January 3, 2009 Report Posted January 3, 2009 If the quad is not for strickly drag I would recommend staying with your inframes, the mounts tend to break on the oofs if the terrain is rough. Other than that, I'd hit jeff up and see which set will work better for the porting he did for you. Good advice right here, ask Jeff... Reguardless of what a dozen other F.A.S.T. bikes might be runnin there maybe a different pipe that suits you and the porting better.. RIPPEN Quote
kawiking Posted January 4, 2009 Report Posted January 4, 2009 Jeff is going to say go with Shearers i bet . I have them on my quad i just got from him a month ago OOF'S both out the left and i like them. But if you plan on duning,jumping at all or have really rough roads i'd keep inframes beause the OOF'S dont mount very sturdy and i think you would crack them out everywhere if u get the oof's ... use rubber washers when u mount them to ur pegs... u will break the welds if u dont. unless ur drag racing all the time.. id go with a set od in frame shears. Quote
sleeper06 Posted January 5, 2009 Author Report Posted January 5, 2009 I talked to jeff he wanted me to switch months ago he said the diffrence on my bike would be night day,If i can afford it i want to keep a set of inframes for play,Jeff said to me huge diffrence in power and since im tryen to run two cubs down i need advantages.He recommended shearers but my buddy highroller355 had a set of cpi and he said the way they hit was incredible or it could be he was used to shearer inframes Quote
