blackandyellowshee Posted December 31, 2008 Report Posted December 31, 2008 Hey I was wondering if a 35mm 2in1 carb set up would be alright for my quad, or is that carb too big? VF3 Reeds, cool head 20cc domes, timing plate +4 degrees, and fmf gold series pipes. No porting or boring or stroking. Thanks Quote
sheerider1026 Posted December 31, 2008 Report Posted December 31, 2008 i have that same setup on mine.. i love the setup for trail riding.. 35 is not too big.. Quote
Misssppelllleddd Posted December 31, 2008 Report Posted December 31, 2008 35 isn't too big...but i did use a 33mm carb with the same setup before..only difference was that I had 19cc domes and it worked great. Quote
BansheeRider87 Posted December 31, 2008 Report Posted December 31, 2008 what if it was two carbs instead of one? does it matter? i know about the low end im just sawing having two 35mm to much instead of the two in 1 kit Quote
Snopczynski Posted December 31, 2008 Report Posted December 31, 2008 Hey I was wondering if a 35mm 2in1 carb set up would be alright for my quad, or is that carb too big? VF3 Reeds, cool head 20cc domes, timing plate +4 degrees, and fmf gold series pipes. No porting or boring or stroking. Thanks Going with the 2 into 1 is sort of going in the opposite direction from all the parts you have installed so far. Everything you have is more of a mid-top setup. Quote
