which jets i have. do they have markings on them or do they have a different shape. my carbs look stock. but they do have k&n pods on them
Pull them out and you will see the #s their tiny.
This is what the stock carbs look like
i know my tors is removed. i don't even know the size of my carbs. i guess i could pull them off and measure.
Well if they look like these their stock 26mm if they have the choke on the left side sticking straight out and have that yellow tube connecting the 2 carbs their stock, your tube will be black.
yeah my choke sticks out the left side and my tube is black. so i guess i am stock in teh carb department. thanks
Your jets will have the numbers written on the bottom of them. When you pull the bowl off the bottom of the carbs you will be able to see the numbers on the jets.
Edited by motor builder
