Snopczynski Posted December 28, 2008 Author Report Posted December 28, 2008 You got 26 votes isn't that close enough haha, I'm curious to see what it actually was... when you give us what they were you should post the charts again and give an explaination Some people didn't vote and hit the view results button. That makes you forfeit your right to vote so you cant see what everyone else put and cheat. Quote
AKheathen Posted December 30, 2008 Report Posted December 30, 2008 ok, it's killin me, and no one has posted in a while :wallbash: Quote
spurdy Posted December 30, 2008 Report Posted December 30, 2008 5 more. Come on Snop. We grow weary and the anticipation is fading. SP Quote
Snopczynski Posted December 30, 2008 Author Report Posted December 30, 2008 Come on Snop. We grow weary and the anticipation is fading. SP Push it hard, 4 more is all we need. Quote
spurdy Posted December 30, 2008 Report Posted December 30, 2008 Push it hard, 4 more is all we need. Its getting limp! Pushing hard is just smashing it! lol! SP Quote
Snopczynski Posted December 30, 2008 Author Report Posted December 30, 2008 Its getting limp! Pushing hard is just smashing it! lol! SP Quote
spurdy Posted December 30, 2008 Report Posted December 30, 2008 Alright......(sigh)....what's the count now? Quote
Snopczynski Posted December 30, 2008 Author Report Posted December 30, 2008 26. ALL PEOPLE HAVE TO DO IS LOOK AT THE CHARTS AND TELL US WHAT THEY THINK! Once we get the 30 results, I will post up a little story on what the deal is with the runs and how the bike was while riding. Only need 4 more. Quote
98_shee Posted December 30, 2008 Report Posted December 30, 2008 (edited) Here's what i chose: The dynoport 2 into 1 pipe with single 35mm pwk, carbon tech low reeds, and 20cc domes. Chart 1. Pro circuit pipes with single 35mm pwk, vf3 reeds and 19cc domes. Chart 2 Pro circuit pipes with dual 28mm mikuni flatslides, vf3 reeds, and 19cc domes. Chart 3 Am i close???????? Let us know Edited December 30, 2008 by 98_shee Quote
Snopczynski Posted December 30, 2008 Author Report Posted December 30, 2008 1 more poll result to go. Quote
278 Posted December 30, 2008 Report Posted December 30, 2008 1 more poll result to go. Theres your one more man, time to reveal the big secret Quote
Snopczynski Posted December 30, 2008 Author Report Posted December 30, 2008 Theres your one more man, time to reveal the big secret They are all in order. It looks like about 55% got graph 1 right. About 35% got graph 2 right. That leaves graph 3 with about 35% getting that one right as well. 1st one is the dynoport setup with the single carb. 2nd one is the pro circuits with the single 35mm pwk. 3rd one is the pro circuits with dual mikuni 28mm flatslides. Graph 1 was a lugging terd. That single pipe would lug and then hit and rev to the moon all of the sudden. Overall it accelerated the slowest out of any pipe I have ridden with on this bike. Once you were on the pipe it was easy to stay on it if you could go fast and didn't let up too much. I had to make the bike wheelie, and it definitely was weak on the topend. Out of the hole it did not even feel close to the torque that the pro circuits make. I hated that pipe and carb setup now that I know what I was missing. Peak rpm was about 8,800 rpm. Graph 2 was a lot better everywhere than graph 1 was. Bottom end felt the same as it does now with my graph 3 setup. Top end was a little different, when I would drag race or hill climb the bike would sort of flatten out a bit and quit pulling at the top. With the twin carbs it will continously pull all the way through every gear in a drag race easy, as when it had a single it would flatten out. On the hills you would hit some inconsistent spots with the single carb, where it may have to be shifted down if you were in a high gear and lost momentum. With dual carbs it will pull rpm and hold it at the least and not slow the bike down. Midrange pull is better with the dual carbs over the single carbs. peak rpm on this setup is about 8,700 rpm. with the hp curve tapering off quite a bit at the end of the run and you can tell when your riding the bike. The Graph 3 setup is the wheelie monster, and its the current setup I run and will continue to run. I did add the dyna cdi, moved to a stock reed cage with carbon tech mid reeds, went to 18cc domes, and put on a dyna coil as well. Its the funnest to ride and pretty much shines everywhere. It does well on the sand trails, in the holes, and climbing hills. It will even manage to win most of the occasional friendly drag races with other 350's and even some 4 mills I know. It accelerates the fastest out of all them, and feels like it makes the most torue out of all of the setups shown. This setup also has a great torque backup. You can let off or slow down and get back on the throttle again and the revs will pick back up. Going to the stock cages from vf3's made the bike pull harder through the midrange and the topend feels the same. Of course on this setup the redline is around 8,750-8,850 rpm with the bike still wanting to make more hp and you can feel it. So the true colors of the vf3 would not shine on a low-mid motor. Ok, between the two dynos here is the deal. I ran the dynoport setup on a rear wheel dynojet. The pro circuit setup was ran on a land and sea crank dyno (way more accurate). The dynoport setup made 50.34 hp and 29.76 ft lbs torque on the dynojet. I did run the graph 3 setup with all the upgrades on that dynojet again this last summer. It made 56.97 hp and 43.87 ft lbs of torque. The pro circuits make much broader power than the dynoport pipe and the bike accelerates much faster and is a whole lot funner to ride. Single carb to dual carbs. Same feeling bottom end, same feeling lower midrange, upper midrange much faster acceleration with twins and much stronger feeling topend with twin carbs. Throttle response feels more crisp with the twin 28mm carbs, and accelration feels faster with the twin carbs. Single carb guys: If the single carb had a low-mid power advantage over the twins, trust me I would be running it. There is no better feeling than going out and outclimbing my cosuins low-mid 4 mill and then beating him in a drag race with my low-mid port 350. If I could get more low-mid power out of it, I would. I have done everything I could do to test all the best power making options. We even dyno tested some custom dyna ignition curves that I made and got that all dialed in. Good news is my porting can go a little further. My intake bridge and the upper intake hump can be worked a little. My transfers can be opened up a little more and my cases can still stand to be matched. So when it blows up, I will get all that done. But till then, this bike is making the most power it can and everything has been squeezed out of it and dialed in for a good strong low-mid setup. Quote
