lt1bird Posted December 25, 2008 Report Posted December 25, 2008 Anyone run sealer on the primary gear? I hear that a super thin coat on the inside of the primary gear shaft....this will help seal up any possable leaks from the crankcase...sucking tranny fluid in... Quote
Dave I. Posted December 25, 2008 Report Posted December 25, 2008 Yes, I even use more than a thin coat...its good to get it around the keyway also. Quote
BigRed350x Posted December 25, 2008 Report Posted December 25, 2008 I had to do the same on a 10mil cheetah I built a while back. It would suck air around the key. I used the red hi-temp gas/oil resistant silicone that you can buy down at any of the auto parts places. Worked perfect. Quote
shanYE west Posted December 25, 2008 Report Posted December 25, 2008 Never used it on any of my builds.. but I do put new seals in every time the motor comes apart. Quote
lt1bird Posted December 25, 2008 Author Report Posted December 25, 2008 So some folks do and some do not....Hmmmmmmmm Quote
MDS2106 Posted December 26, 2008 Report Posted December 26, 2008 I have never used it.I have heard of using it but never had the need. Mark Quote
lt1bird Posted December 26, 2008 Author Report Posted December 26, 2008 Think ill run a bead in between the primary gear and the water pump gear....it will get trapped in there from the gear anyway...this way it will seal but still come off easy Quote
BigRed350x Posted December 26, 2008 Report Posted December 26, 2008 I think it might have to do with what crank you run as well. Some of the cranks have the keyway milled back farther towards the web of the crank, but some don't. I had a billet 10mil crank from twister that didn't need it and I had a 10mil crank from cascade that had the key-way milled back quite a bit father than the other crank and it had a nasty air leak past the key when I leak-down tested it. Some of the cranks are milled back through where the crank seal actually seals and some don't. I've never had a 4mil crank that needed it. Quote
Dave I. Posted December 26, 2008 Report Posted December 26, 2008 yea my stock crank and stock gears didnt need it. My billet crank and straight cuts leaked like crazy......just depends what combo you run.....doesnt hurt anything to put some sealer on anyway. Quote
