1baddshee Posted December 25, 2008 Report Posted December 25, 2008 ok i have a 96 banshee the shee runs very good now the only problem im having is when i hit some water it boogs out then it dont wants to run until i guess it drys out do any one have any solutions on what is causeing this problem to me it feels like water is get in somewere where its not suppose to any ideas on what it is i will greatly appriciated Quote
2/2 many banshees Posted December 25, 2008 Report Posted December 25, 2008 sound like it's the water stay out of it and it's fixed. just playing how deep is the water you are going it what is getting wet? Quote
mark101180 Posted December 25, 2008 Report Posted December 25, 2008 mine does the same thing when i cross creeks. it will stay running but not right for a bit. im probably wrong but i personally think it may be getting cooled right down and it was too warm back up again Quote
tony cub Posted December 25, 2008 Report Posted December 25, 2008 if you running pods filters it might be getting back into the carb..do you have the rubber gasket around the stator cover?if not that also may be a problem. Quote
1baddshee Posted December 25, 2008 Author Report Posted December 25, 2008 if you running pods filters it might be getting back into the carb..do you have the rubber gasket around the stator cover?if not that also may be a problem. im gonna have to check that cause someone told me to check the rubber gasket to so ill check that but it could be a little puddle of water and soon as i zoom threw it it starts acting up at one time the throttle got stuck scary Quote
1baddshee Posted December 25, 2008 Author Report Posted December 25, 2008 sound like it's the water stay out of it and it's fixed. just playing how deep is the water you are going it what is getting wet? it is not deep puddles im talking about and its the bottom of it that gets wet Quote
Wildcardracing Posted December 25, 2008 Report Posted December 25, 2008 im gonna have to check that cause someone told me to check the rubber gasket to so ill check that but it could be a little puddle of water and soon as i zoom threw it it starts acting up at one time the throttle got stuck scary If your throttle got stuck then you are getting water into your carbs. If you have an open air filter you need to go back to the stock type air box or stay out of the water. Quote
killshee Posted December 25, 2008 Report Posted December 25, 2008 it is not deep puddles im talking about and its the bottom of it that gets wet u say its not much water .... if u have pods i would stay outa the water ....anyways check for any bare wires or anything that could b getting wet ...if there is any wires that a bare they could b working as a kill switch when they get wet killing you spark .... i had this happen b4... got stuck in a field for like a half/hour till i figure it out Quote
someone82 Posted December 25, 2008 Report Posted December 25, 2008 Be Careful, sucking water into the carbs and into the motor can cause bad things. Water doesn't compress so you can bend rods real quickly. Also Having the cold water hit the intake side of a pistons can cause cracks and failure as well (I've had it happen to me). Does the motor struggle to run? Does it sputter and you can't get it to rev worth crap? If so it sounds to me that you are sucking water into the carbs. If this is the case, shut the motor down right away (don't try to keep it running, that's where the damage will really o-cure) , pull the plugs and drain the cylinders (tip the bike on the side) and let them dry out. matt Quote
pitkendall Posted December 25, 2008 Report Posted December 25, 2008 (edited) it could be when u hit the water it splashes up onto the tors wires and crosses the circut activating the tors system till the water droplet dries up away from the two wires then it starts running better cuz the circuit is no longer compleated and the tors system is no longer activated Edited December 25, 2008 by pitkendall Quote
tony cub Posted December 25, 2008 Report Posted December 25, 2008 best thing to do...stay out of the water..and more if you have open air box or pods.banshees dont take to the water very well. Quote
1baddshee Posted December 25, 2008 Author Report Posted December 25, 2008 thanks every one for the info yeah ur right when i hit the puddles it does bogg an acts like it doesnt wanna start and if it does start you could hold it full throttle and all it does is spudder it doesnt rev or nothing it just stays on but wit no rev it only happens when i hit the puddles so i deffently stay out off anything bigger then a puddle i think it take in water from somewere just dont know where Quote
j_rod421 Posted December 26, 2008 Report Posted December 26, 2008 ok i have a 96 banshee the shee runs very good now the only problem im having is when i hit some water it boogs out then it dont wants to run until i guess it drys out do any one have any solutions on what is causeing this problem to me it feels like water is get in somewere where its not suppose to any ideas on what it is i will greatly appriciated That sounds like a small vacuum leak to me. If your being nice and takin it semi-easy through some puddles, the moisture in the air concentrated around the engine compartment can do enough to make it cut out, die, or sometimes nothing at all. I say this especially if you throttle is trying to wander around on you with out actually sticking. But at the same time I could very well be electrical or pod filter related. If your wiring looks good, you don't think the filters are letting water in, clean the bike up and closely inspect all your base gaskets and intake gaskets then check your torque on your cylinders. Or hell, just run it and take a squirt bottle to the bases and see if the bike struggles to run when you spray them. Hope it helps you! Quote
AKheathen Posted December 26, 2008 Report Posted December 26, 2008 it could be when u hit the water it splashes up onto the tors wires and crosses the circut activating the tors system till the water droplet dries up away from the two wires then it starts running better cuz the circuit is no longer compleated and the tors system is no longer activated the tors wires act in on or of. nothing in between. if this were to happen, it would just cut out. check thew plug wires for chaffing, and use some tune-up grease on the caps. (silicone- dielectric grease) that is the intended purpose of the grease. check for air leaks, check the gasket around the stator cover, and run an air box, probably wont need the lid Quote
AKheathen Posted December 26, 2008 Report Posted December 26, 2008 the tors wires act in on or of. nothing in between. if this were to happen, it would just cut out. check thew plug wires for chaffing, and use some tune-up grease on the caps. (silicone- dielectric grease) that is the intended purpose of the grease. check for air leaks, check the gasket around the stator cover, and run an air box, probably wont need the lid also, are you running good outerwears? Quote
