longer pod filters? i was wondering this when i was ordering foam pods, and chose to go with shorter ones because of worrying about them getting splashed from puddles. but what is the difference? i would imagine the longer have a little better airflow, but comon really? could it be that much more?
if your riding in areas with water I wouldnt get pods, Now when you say spalshed by water what exactly do you mean?
The reason guys get longer pods is becasue on bigger motors they need more air.
if you ride in water you might wanna consider using the stock air box with a pro flow kit or something that uses anything but the stock filter. you can always run the box with no lid. that will greatly reduce the risk of your motor sucking in some water.
You can trail ride with pods... I do and have no problems.
If there is water...find a way around it, or find a way to hydro plane across it. Avoid it like the plague.
Obviously if you go mud bogging and splashing through puddles, your bike will suck in water.
primary riding is ... and takin donkeys for rides at partys in the woods.
Hahah anytime you go to a party in the woods, everyone wants a piece of the 'Shee.
