take it on pavement, run it hard and it will sound like the motor revs instantly but you arnt accelerating like you should, the revs climb fast and you arnt going as fast as u used to
when i hold the clutch and shift into 1st or 2nd, it moves front abit like 5inch? is that like normal
and i hear some little sound when i try putting it back into neutral from 1st or 2nd,
+ the clutch shift is getting smooth
Have you adjusted your cable at the perch/lever? should only have a little bit of play, maybe a 1/8 -1/4 at tip of lever outer.
i let it as i got it when i had my clutches placed by the shop i went to, i have like 0 clue in mechanics with bikes ;/ but ye its abit lose , but wut about it moving abit when i first shift into 1 or 2 b4 moving? or small cracks when i try putting bk into N
