bansheejoel Posted December 16, 2008 Report Posted December 16, 2008 My shee has been sitting for about a month and a half. I started it today and at idle it seems to load up and drop the right cylinder. If i rev it up it clears up and picks it back up. Do you think the carb needs to me cleaned? thanks Quote
98_shee Posted December 16, 2008 Report Posted December 16, 2008 sounds like pilots could be stoped up, i would clean them and sync them. Quote
banshee_terror_ Posted December 16, 2008 Report Posted December 16, 2008 give that a try but thats probly it thow Quote
dajogejr Posted December 16, 2008 Report Posted December 16, 2008 Get a speaker wire and brake clean for the pilots. A lot of time, carb cleaner and compressed air alone won't do it. Those pilot jet holes are TINY..... Quote
spurdy Posted December 16, 2008 Report Posted December 16, 2008 Don't for get to check the sync between them also. Mine does the same thing when they are out of sync. SP Quote
bansheejoel Posted December 17, 2008 Author Report Posted December 17, 2008 thanks guys. Usually my carbs are spotless but michigans winter put the shee on the back burner for a while. Quote
jimbob Posted December 17, 2008 Report Posted December 17, 2008 have you tried swapping the plugs over? i had this is few weeks ago and it was a crappy plug, new ones sorted it straight out Quote
AKheathen Posted December 17, 2008 Report Posted December 17, 2008 could be a float needle too :shrug: Quote
