I had my stock one modded neutral in all the way down 1-5override. only cost 300 if you drag race alot its worth it. I cant see riding a trail bike with one. The guy who cut my trans said its bad to down shift them alot.
Half right...
The old style overrides, or...non-dunable, it was a bad idea to backload the tranny a lot, in other words, let off the gas without the clutch pulled in.
Newer style Dunables are not like that. You can ride them like a normal tranny, but full power upshifts without the clutch.
You shouldn't download them excessively...but, you'll just wear the shift forks sooner....
if you do any type or racing then a override tranny is the way you go. now it depends on the type of racing you do which override you want. i have a 1-3 overrider in my atc 500r, 1-6 in my stock banshee. i got tired of slap clutching and missing gears. believe me a missed gear will cost you the race (money). it's ok to down shift the tranny but only when you have come to a COMLPETE STOP...if you dont stop then you will mess up something in the tranny. most likely the shift forks.
That is true only of the 1-6 override for a banshee at this time. WCR is working on a dunable 1-6...but it is pricey, and he's still ironing out the kinks.
Other cuts, 1-5, 2-5 and 1-4 allow for downshifting while moving...but with the clutch pulled in.
hmmm. i have a cheetah motor on my shee (392) that i do a lot with,(trail ride, rec riding, woods, and drag it) not sure if a dunable is for me? will backloading the dunables a lot mess up the forks?? or is it downshifting that does it?? just wondering if theres a way i can use one and not mess it up ( dont wanna take the motor back apart for a while)
If you backload it excessively over 8,000 RPM, it will wear the shift forks sooner.
