too_fazt Posted December 13, 2008 Report Posted December 13, 2008 34 pjs cool head (cant remember the domes compression is at 120) drag porting vf2 reeds shearer inframes stock bore. sea level. chime in. i need a starting point. thanks Quote
dragbanshee Posted December 13, 2008 Report Posted December 13, 2008 34 pjscool head (cant remember the domes compression is at 120) drag porting vf2 reeds shearer inframes stock bore. sea level. chime in. i need a starting point. thanks So whats up with it? Did you redo it, Just buy it, does it run now? Comp. seems kinda low to me, with the cool head on there, or you just have the 22 domes. Quote
too_fazt Posted December 13, 2008 Author Report Posted December 13, 2008 So whats up with it? Did you redo it, Just buy it, does it run now? Comp. seems kinda low to me, with the cool head on there, or you just have the 22 domes. just slapped her together, i didnt look at the domes, they could easily be 22s. and i know the carbs are running rich at all aspects. idle, 2/4 3/4 wot. they came off a bigger motor which i expected. im not familiar with pjs. so id like a starting points so wen i take her out i can dial in further from there. other then that shes running well, just fat. Quote
dragbanshee Posted December 13, 2008 Report Posted December 13, 2008 Not familiar with the pjs but aleast you have a little more info for others to help out, do you know what the current jetting is? I would think atleast 50 pilots and 162 mains. :shrug: Quote
too_fazt Posted December 18, 2008 Author Report Posted December 18, 2008 Not familiar with the pjs but aleast you have a little more info for others to help out, do you know what the current jetting is? I would think atleast 50 pilots and 162 mains. :shrug: had 160 in them. droppin down to 155. well see how it goes Quote
willbanshee Posted December 19, 2008 Report Posted December 19, 2008 had 160 in them. droppin down to 155. well see how it goes I am having a similar problem jetting my shee i am running the same set up but have 22cc domes and run 145psi, i have the shear inframe pipes, trinity reeds, im bored .80 over and just put 34pjs on mine. I am at sea level to and started with 158 and 45 with CEL needle with clip in middle and when i hit the gas it bogs. So i dropped my needle down a Enoch today and still same so i put some 50 pilots and its a little better but still bogs. tomorrow i am going to try 55 pilots and will keep you informed. Quote
