Banshee_hillshooter4 Posted December 11, 2008 Report Posted December 11, 2008 (edited) I have a 2001 Banshee and Im not completely sure what it has but I do know it has 35mm mikuni carbs with the tors taken off, it has uni pod filters right on the carbs (no air box), it looks to have reed spacers, so I think it has reed valves too. What would be the best jet settings for toomey t5s?? I will be riding at sea level.... Edited December 11, 2008 by Banshee_hillshooter4 Quote
firebanshee Posted December 11, 2008 Report Posted December 11, 2008 I have a 2001 Banshee and Im not completely sure what it has but I do know it has 35mm mikuni carbs with the tors taken off, it has uni pod filters right on the carbs (no air box), it looks to have reed spacers, so I think it has reed valves too. What would be the best jet settings for toomey t5s?? I will be riding at sea level.... I would start at 350 and drop if needed i think you will be between 350-330 main 27.5 pilot middle clip on needle. About 1 and 3/4 turn on air screw should be a good starting point. Quote
