I think there skid plate hangs down tooooo low. I want as much ground clearance as possible you know? Ill be sure to send you one for sure.
haha, i knew there was another reason why i didnt go w there skid plate and thats it it hangs too low. good call
peter
no i dont. ive always ran a prm skid plate so i sent the skid plate to edwin. he then installed the tabs to the swingarm based on the skid plate. so if you have a skid plate you want to run then just send it to avenger before they build it and youll be all set. as for the skid plate they offer, its a real good skid plate. pretty sure its bullet proof. i almost went with it but decided not too for the reason mentioned above. ive just always run prm, never had a problem so theres no reaon to "fix it if its not broken," lol.
pm me when your ready to buy one and ill give him a call for you.
peter
hopefully i get some christmas money, and i will be able to get 2 +2 swingarms. then i will need new chains, and brake lines, will i have to get my shocks redone? (i have works shocks on back in both)
If you get them with the stock dogbone mount the shocks will still work.
I think the rear brake line has enough length for a +2 as well.
But don't quote me on that cuz I'm not positive.
If you are very picky you will want to have the shocks re-valved for the longer swingarm. They will bolt up just fine, but will be a lot softer.
yep i am, so ill have to send all 6 of my shocks out to works.
who makes a stock length round carrier swingarm that i can use the prm z-swingarm plate with?
just in case you didnt catch this:
if you go with an Avenger swingarm you can send them your prm z skid plate and they will make sure it fits. they will install the tabs based around the skid plate you want to use.
peter
peter
that is definetly what i will do when i am doing new swingers.
