My shee is making a ton of noise, from the bottom nylon roller. I Chain waxed it not much change, is this a normal noise or should I replace both the top and bottom rollers?One other thing prev. owner crossthreaded the crank case fill cap/dip stick is there and metal one out there
Edited by steeler2169
You may want to change the oem chain guide above the front of the swingarm as they make alot of noise when new let alone when worn out. Go to this style:
http://www.farmandsandtoys.com/partdetail.asp?partid=141
I dont usually run the upper roller but you can feel and listen to your bottom roller to see if it is worn.
Make sure that's what it is. About 2 weeks ago, I thought my bottom chain slider was making noise too. Turned out it was the axle bearings. Might want to check those too.
Good call, jack it up and spin everything, pay attention to your chain as it could have rollers or pins in bad shape too.
