Custom Banshee part out
CHASSIS
$2200 2008 built custom 4130 chromoly +2 stretch frame (This is a Custom frame NOT stock a modded frame) .065 wall with baja style front suspension
Custom +1.5" 4130 chromoly antivibe stem
Custom +2 +0 4130 chromoly a-arms 0.95 lowers and .065 uppers
$275 (like new)Custom 4130 chromoly +4 swingarm .095 wall
$100 (like new) Polished JJandA 40mm carrier
$550 (like new) JJandA billet play axle with Billet hubs and sprocket and brake assembly
$60 (rebuilt) YFZ450 twin piston rear caliper
$25 (like new) Stainless braided rear brakeline
$75 (clean) Polished front YFZ450 spindles (reamed)
$60 (clean) YFZ450 front hubs
$60 (clean) 01 raptor rear shock (+2 over stock)
$40 (clean new) bearings Polished rear link
$120 (like new) Cascade polished billet pegs w/ extra mounts for peg relocation
$20 (like new) Chrome shifter
$70 (New) DID 520 chain
$30 (like new) Primary drive sprockets
$300 (like new) Custom painted Fullbore front plastic (white w/ platnum pearl)
$60 (clean) Custom white seat
$50 (like new) Trail Tech X-bars Polished
$25 (like new) ODI lock on grips
$25 (clean) Polished TRX400 throttle
$25 (like new) Billet on the fly adjust Clutch lever
$20 (like New) cables
$65 like new) Houser Antivibe bar clamp
$200 like new) Boss oversized radiator
MOTOR
$500 (like new) stockbore cylinders w/ Passion 12 port mild dune/drag porting with pistons
$130 (clean head new domes) Pro design cool head w/ 18cc Noss domes
$20 (like new) Chrome bullet head nuts
$300 (like new) Custom built Stock crank with aftermarket stock length rods ( crank has been trued, welded, and cryo'ed)
$150 Tranny has been totally disassembled and inspected
all bearings and seals in tranny are new
$80 (ok) Port matched cases
$35 (like new) Tm Designs composite case saver
$150 (like new) Cascade Billet stator cover
Stainless allen head bolt kit for whole motor new
$150 (like new) P.E. Billet clutch basket
$50 (New) OEM Pressure plate,rod,ball, etc
$60 (like new) FZR600 clutch fibers
All new water pump seals and bearings
$15 (clean)Easy Drain Pro Design water pump cover
$175 (new)Professional polished clutch cover w/ all billet inserts and wp- cover
$50 (ok, has marks)Billet kicker
$100 (like new) Boss billet intakes
$40 (clean) Stock cages w/Boysen reeds
$185 (Like New) PWK 33mm carbs
$80 (New) Real K&N 10" filters
$400 (like new) CPI pipes and polished silencers
$115 (clean) Dune runner fronts on polished douglas
$325 (like new) 21x12x8 10 paddle Skat Trak on polished douglas
or I will take $7600 for the whole bike
motor rated @74hp and weighs Appox 260# . This bike runs with the Cheetah Cubs and big bore bikes
Everything is new and has been rode 3 dune trips and has been tested and runs great and is very fast. I am ready to build my next project so it is time for this to go.
Edited by dunerman
Not trying to start trouble....but that sure does look a lot like a stock modded frame. It has definitely had a ton of work done to it, but the swingarm mount, rear shock and engine mounts all look stock. The only reason I mention it is you do not want to have the drama of selling someone something and it coming back to bite you.
On another note.....it is one sweet bike!!!!!
No, Its not stock. Its all 4130 chromoly. I used a few stock tabs for the rear shock and foot pegs and the gusset for the steering hopp but thats it. I have pictures before it was coated if you need to see them .
I will say this frame was instired but the built you posted. It is your design for the front end . I liked it alot
thanks
