bansheee87 Posted November 5, 2008 Report Posted November 5, 2008 what fuel should i be running? my mods are +3 timing, 22cc domes just check compresson 130 psi with motor cold, 4 mill crank not ported. im at sea level too thanks Quote
stageIVbanshee Posted November 5, 2008 Report Posted November 5, 2008 i run 93 with 20cc domes. thought about 110 octane but it is expensive!! Quote
bansheejoel Posted November 5, 2008 Report Posted November 5, 2008 Fuel octane goes by compression and timing......your low enough on compression and timing Quote
OKCterror Posted November 5, 2008 Report Posted November 5, 2008 pump 93 with the occassional booster Quote
2001Stroker Posted November 5, 2008 Report Posted November 5, 2008 If you need race fuel, then use it. It may be expensive, but an engine is more expensive. Detonation will kill a top end, quick. bansh-eman, fouldout, locogato, and a few other guys that are extremely experienced 2-strokers can tell you the formula for figuring your compression ratio. That is what you need to know when buying fuel. Don't use octane booster. It's not consistant. And just to add to bansheejoel's post, also goes by altitude. Quote
