My Motor Mods are:
Open air box with prodesign filter setup
Vforce 2 reeds with spacers
FMF Gold Series pipes
+4 Timing advance
28mm Keihin carbs
I currently have 155 mains and 45 pilots, Air screw 1.5 turns out. When I start it idles really high and I have somewhat adjusted that. I need some help in getting these carbs dialed in correctly. Amy advice would be greatly appreciated.
You should be real close on the jetting, check your cables at the carbs, idle adjustment. Make sure your cable keepers are both locked in, something other than jetting. I know when I start mine up with the choke it idles a little higher than I like but I just shut the chokes down real quick.
I can't get these carbs to idle as crispy as my stockers for some reason. I am gonna put some 50 pilots in them and see how it idles and runs. Are my main jets to rich or are they pretty good????
Im gonna order a set of 50 pilots today and throw them on and see what happens. I think I need a new throttle cable also. I dont know what type of needle I have in the carb, but what clip should I be using and what clip to set it on??
